Squeaking Very LOUD
Old 02-13-09, 01:21 PM
bezee
bezee's Avatar
Default Squeaking Very LOUD
I have a 1995 SC400 and would a dryish serpetine belt be the cause of a really loud obnoxious sqeaking?? Ive had a squeaking problem previously but that was due to my coolant reservoir leaking and the belt getting wet. Any ideas or suggestions would be greatly appreciated
Old 02-13-09, 01:28 PM
SC300_704
SC300_704's Avatar
buy a gatorback serpentine belt at autozone..it helped w/ my sqeaking...
Old 02-13-09, 07:43 PM
UZZ30-SC4
UZZ30-SC4's Avatar
That gatorback is most probably a patch job on a worse problem
Old 02-13-09, 07:50 PM
IndecentSC
IndecentSC's Avatar
i have the same problem but mine is a 300..if the belt doesn't help its probably your tensioner
Old 02-13-09, 09:07 PM
bangdangvn
bangdangvn's Avatar
I had the same problem except in the sc300. I replaced the bearing for the tensioner, but it did not stop. The crank pulley fell out while I was on the highway and damaged the fan. After looking under the hood, found out the harmonic balancer/pulley separated. There's a lot more information in the performance section.
Old 02-15-09, 04:46 PM
Supra Dr
Moving SC Threads
Supra Dr's Avatar
Moved to engine section
King700se
01-07-16 03:54 PM
BradyJ10
12-30-14 11:43 AM
vipsc400
SC- 1st Gen (1992-2000)
14
07-06-11 09:23 PM
kez
07-24-10 06:41 PM
SC300T
Performance
06-18-04 09:42 AM
Quick Reply: Squeaking Very LOUD
