AEM map sensor install on 1jz
Not sure if any one else has done this or not but i have a AEM map sensor 2.1 bar and id like to get it wired in and was wondering if anyone has the pin out on the 1jz.
i know for a 2jz it is:
Wiring:
Pin A: Ground (brown wire) (E)
Pin B: Signal (yellow/green wire) ECU Pin 66B-->62B (KS)***
Pin C: +5V Reference (blue/red wire) ECU Pin 41B (VC)
1jz has brown(im assuming it is ground, turquoise/black and blue/red
has anyone wired one in and wouldn't mind sharing it with me?
Wiring:
stillfly45
Performance & Maintenance
05-15-13 08:45 AM
