Whos ordering the new BL compound turbo kit?
Old 02-17-09, 06:00 AM
RyanV
RyanV's Avatar
Default Whos ordering the new BL compound turbo kit?
http://www.supraforums.com/forum/sho...d.php?t=527336
This is installed on the Boost Logic 1995 blk/blk Sc300 right now. Super sick...
Old 02-17-09, 06:24 AM
JPSFAB
JPSFAB's Avatar
Wow!!! That kit looks really nice. What's the cost on the kit? How much power did the BL car make?
Old 02-17-09, 08:27 AM
RyanV
RyanV's Avatar
I can't speak for them, but I think the initial dyno chart says 600+
The cool thing with the kit is the power delivery.
Old 02-17-09, 08:45 AM
ICONYQ
ICONYQ's Avatar
on the thread I think it was saying in the $7-$10K range.
yea they need to get a larger turbo for 1K I belive. It is a sweet setup but my interpretation is less lag = $7K
Old 02-17-09, 11:15 AM
plex
1UZFE/2JZGTE
plex's Avatar
What are the exact benefits of a compound system. I've heard about it but not that familiar with the concept. I know it's widely used in diesel applications and a bigger turbo feeds the smaller one but that's it. Experts chime in please lol.
Old 02-17-09, 01:26 PM
RyanV
RyanV's Avatar
*Im no expert*
The way it was explained to me, is that basically your getting the spooling benefits of both a smaller 'single' turbo down low, and the larger 'single' turbo up top while greatly reducing if not eliminating massive turbo lag.
The wastegate situation is tricky because the system is engineered to let the smaller turbo freewheel once the larger turbo takes over.
**It’s more about broadening the power available over a much wider rpm range.
Old 02-17-09, 01:52 PM
SC300_704
SC300_704's Avatar
damn i want that kit!! to bad i can't afford it...
Old 02-17-09, 05:34 PM
t70 supra
t70 supra's Avatar
is cheaper to piece a kit together
Old 02-17-09, 05:50 PM
YeA 2jZ
YeA 2jZ's Avatar
Damn looks like i need to start saving... 300hp 22psi @ 3000k rpm on a stock GE i think is worth it
Old 02-18-09, 09:00 PM
PM Supra
PM Supra's Avatar
I get the first one
Old 02-19-09, 05:31 AM
plex
1UZFE/2JZGTE
plex's Avatar
Of course you can piece a single kit together for cheaper but this isn't a single kit.
Old 02-19-09, 06:59 AM
DasBach
DasBach's Avatar
Most likely not. This isn't like putting together a single, or finding upgrades for your stock twins.
There is a lot more science behind this I'd think.
Old 02-19-09, 07:30 AM
TougeSC3
TougeSC3's Avatar
The research and development that went into this kit should not be peiced together. It's not as simple as a manifold and 2 turbos. The turbos, turbo housing and wheels, exhaust plumping and actuation of it all has be carefully balanced so that it all runs fluidly.
Originally Posted by PM Supra
I get the first one
This is why I hate you Chris. Now from what I've heard is this on a 2JZ-GE, or was it an GE-GTE conversion?
Old 02-19-09, 09:38 AM
ihiryu
ihiryu's Avatar
Well IIRC the test car was a 2jzge. Mark's car, but I don't think it's 100% stock though. Regardless, the kit looks great, and apparently it works.
Old 02-19-09, 09:14 PM
PM Supra
PM Supra's Avatar
Testing was on a another turbo GE. I had to pull out my 40K mile GE-T out of my Black SC and install a built 3.0 GTE for this project. We also bumping up the bigger turbo from a 76mm to a 80mm.
Quick Reply: Whos ordering the new BL compound turbo kit?
