1.5jz swap ???
Old 02-22-09, 11:23 AM
t70 supra
t70 supra's Avatar
Default 1.5jz swap ???
i am getting ready to order my soarer 1j head what all do i need for my swap please chime in if u have info or have complete the swap this is my second swap in 5 years so i am RUSTY as ever
Old 02-23-09, 08:12 AM
t70 supra
t70 supra's Avatar
bump i know some 1 here has done this
Old 02-23-09, 10:26 AM
r1ce
r1ce's Avatar
i want info on this too. i started my and been using http://www.toymods.net/forums/ there really helpful and they have alot of odd swaps and helpful threads on this stuff, as here this forum no one seems to help alot. hope that helps
Old 02-23-09, 04:14 PM
That-Guy
That-Guy's Avatar
if you've already got a 2jz bottom, why go with a 1jz head instead of the 2jz, it may be a little pricier, but a 2jz beats a 1.5 jz, i believe the only times a 1.5 jz is effective are the times when somebodys got 2 pieces lying around 1 from each motor.
Old 02-23-09, 04:52 PM
Psionic
Psionic's Avatar
Because all the plumbing is already there, turbo head vs. na head.
Old 02-23-09, 06:26 PM
shern
shern's Avatar
The debate on the flow characteristics of the 1JZ head vs. the 2JZ head exists. I have read quite a few times that the 1JZ flows a bit better.
Plus, if your electronics are already in place for the 1JZ, it's much easier to use a 2JZ short block than trying to convert over to a 2JZ-GTE engine management package.
Old 02-23-09, 06:57 PM
t70 supra
t70 supra's Avatar
I got safcii but i am thinking about going fcon but i dont know as of yet we wi have to see how this economy lets me do it or not but as of now i am going to run a ct26 with a ebay manifole and seee what happens
Old 02-24-09, 04:33 AM
aka paco
aka paco's Avatar
like shern basically said, 1jz came in Soarer's the 2jzgte didn't
doing a 1jz swap is pretty straight forward while the 2jzgte isn't, so if you do a 1.5jz you get the ease of a 1jz swap but get to keep your displacement..
Old 02-24-09, 07:48 AM
StiCk3
StiCk3's Avatar
I've read quite the opposite, that the 1JZ head doesn't flow as much as a 2JZ head. I think someone on Supraforums proved this on a flow bench. However the argument of port velocities comes in saying that the 1JZ has higher port velocities which could lead to quicker spoolup. This is all jiberish to me though.
http://www.supraforums.com/forum/sho...d.php?t=339560
Old 02-26-09, 03:43 PM
CCC-TT
CCC-TT's Avatar
Good Luck with the build, i hope to see a nice write-up at the end
Old 02-26-09, 07:05 PM
t70 supra
t70 supra's Avatar
thank u might be awhile but the wait is worth it
Old 02-26-09, 09:40 PM
2jzlex
2jzlex's Avatar
Winner winner chicken dinner. Where did any of you read that the 1jz head "flows" better?
Old 02-26-09, 09:50 PM
Slow_Sc3
Slow_Sc3's Avatar
I have a 1.5jz-gte pm me your questions.
1jz-gte head
2jz-gte block
ge works but your going to want pistons and rods unless your on stock twins.
Old 02-26-09, 10:34 PM
StiCk3
StiCk3's Avatar
So, where's my chicken dinner???
I think that the misconception rose from JDM swappers doing a 1JZ head swap on their cars. I've lost count to how many JDM Chasers have done this swap. It might have to do with the JDM head design or just overall cost and availability of the conversion overseas, who knows. Then again, there are a few 1JZ VVTi head swaps out there and who know how much those flow. Probably not by much though.
In any case, i didn't mean to rain down on the build party. Keep it up and prove me wrong!
sakataj
Performance
10-29-08 08:30 AM
hershsc400
07-05-08 10:49 AM
YupImJOee
GS - 1st Gen (1993-1997)
01-07-08 05:15 PM
ajayR
09-16-05 10:44 AM
Quick Reply: 1.5jz swap ???
