Starter removal issue - need urgent help
Hi!
I guess my starter is dead (car do not start anymore, loud clicking sounds - battery is OK), so I decided to take it out - after 16 years and 200k it should be checked anyway.
I removed everything above the starter (intakes, etc...), but I cannot remove the water bridge because it interferes with the wiring harness above it. Does anyone have any instructions or manual or something which could help me removing those parts? I know it is possible to remove the starter without removing the water bridge, but I do not have the tools for it, and I do not have a small hand
Thanks for help guys & girlz.
get a adjustable wrench i even used a ratchet with adjustable joints but its harder but do able. just take off two starter bolts on the bellhousing on the left side. if you are going to use a tool once better off just buying it sucks not having tools.
its a 400, and its a pita
I'm still not able to put anything near the starter bolts, because of the water bridge and the wiring above it.
I just got an adjustable wrench, but I need more space. For me its impossible to put it on the starter bolts without removing the things above them.
Un bolt as many bolts to the wirnign harness as possible. This will allow you to wiggle it around a bit. Take all the bolts to the water neck off this will allow you to wiggle that as well then take a ractchet with a deep set socket. Medium deep set, and you can un do the starter bolts.
Thats how I did it because I couldn't get to the bolts on that copper piping that go to the back of the water neck..
It also helps a ton if you take your hood off and actually get on top of the motor. No joke i was sitting and laying on top of my engine to do this
I took all 4 bolts from the water bridge off, it moves a little but not much. On the wiring I found only 2 bolts (on the rear side of the water bridge, of course, great engineering)... there should be more because it still barely moves. Any advice where to look for them?
starter contacts are bad if clicking.
Once you get the thing out. Try changing the starter contacts inside the solenoid side of the the starter before purchasing a new one they are about $27USD at the dealerships or you can order them online. I changed mine out and its been going strong for over 6 months. It was on a 300 but the starters toyota uses can normally be fixed like this.
30 bucks fixed!
http://www.youtube.com/watch?v=CxjPp...layer_embedded
