Apexi AFC Neo Help! Car Starts, Rough Idle, Then Stall
Old 03-01-09, 10:28 PM
  #31
vindedreal
vindedreal's Avatar
When I installed my SAFC, the manual was wrong, So I called APEXI , and had them send me the correct updated one, where the 2jzge (OBD1) Is listed as a Karman sensor. These are the Pinouts that worked (Karman sensor is 66! a yellow and green wire) , directly from APEXI, after I spoke with them, they emailed me. BTW like i said in my earlier post, I was in the same situation, I did everything correctly, My unit was defective. Send it in!
Attached Thumbnails Apexi AFC Neo Help! Car Starts, Rough Idle, Then Stall-apex1.gif
Old 03-01-09, 10:29 PM
  #32
vindedreal
vindedreal's Avatar
Second page
Attached Thumbnails Apexi AFC Neo Help! Car Starts, Rough Idle, Then Stall-apex2.gif
Old 03-02-09, 05:33 PM
  #33
sc-driver
sc-driver's Avatar
straight from Apexi
Attached Thumbnails Apexi AFC Neo Help! Car Starts, Rough Idle, Then Stall-neo-upgrade.jpg
Old 03-02-09, 06:47 PM
  #34
ICONYQ
ICONYQ's Avatar
thats ****ty...sorry to hear that man. Well atleast you know you are not crazy
Old 03-02-09, 09:25 PM
  #35
drft_n_sc
drft_n_sc's Avatar
well at least you're getting a tee shirt out of the deal!
Old 03-27-09, 05:54 PM
  #36
sc-driver
sc-driver's Avatar
Okay got it working! The 96 have different MAF's and I'm guessing they're hotwire instead of karman.
Thank you everyone for helping
Old 06-10-10, 07:48 AM
  #37
BAD954BOI
BAD954BOI's Avatar
do we use the orange wire? and if so that do we use it for?
Old 06-10-10, 01:03 PM
  #38
sc-driver
sc-driver's Avatar
The orange wire is so that the display dims when you turn on your headlights. I highly suggest wiring it in since at night this thing can get pretty bright.
I think you just wire it to a 12 volt source that gets current when the lights go on. I think that light in the glove box works, or the light under the cigarette lighter.
Old 12-18-13, 05:17 AM
  #39
Hotrash
Hotrash's Avatar
Originally Posted by sc-driver
Hmmm. I can try that, but I am pretty sure that all 1uz-fe's used a Karman maf sensor. I researched this extensively and that's what it all pointed towards.
The 96+ SC300 are the ones with a Pressure Sensor.
If im not mistaken 1996 + hot wire type
that209kid
07-12-17 09:19 PM
Bigdogsc
SC- 1st Gen (1992-2000)
11-15-15 06:45 PM
SC51
04-17-10 07:25 PM
kenji0104
IS - 1st Gen (2001-2005)
03-20-04 11:49 PM
SPORTcoupe
02-23-04 04:54 PM
Quick Reply: Apexi AFC Neo Help! Car Starts, Rough Idle, Then Stall
