is my car miss firing?
guys i do not know whats wrong with my car... when i accelerate it seem like its not responding as good as before.. the car feels sluggish, or a lag.. i dont think its my transmission because my rpm doesnt go up high as if i was revving.. so does this mean i need to change out my spark plug wires? how do i know if im miss firing? can someone plz explain?
with a misfire the car will sound like utter crap. You'll also notice some jerking as the car is under load. Slow response could be a number of things like a dirty MAF, bad TPS, or even a dirty air filter. Check to see if there are any codes in the ECU first then come back to here.
Search and ye shall find....
http://www.troublecodes.net/Toyota/
look for the connector under the dash on left of the drivers side or under the hood. E1 and TE1 will be marked
you can tell if it's misfiring because it will shake once in a while. if it's just like a slight shake and not too bad, check your sprak plugs and wires. the wires just pull one off at a time. i did that but turned my car off each time, cuz didn't know if i could do it with it on, pulled one off and my car ran better without it.
scweetfl02
Performance & Maintenance
10-13-12 10:05 AM
lp_yang
17
04-26-08 10:56 AM
