Custom exhaust
Today I had custom bent 2.5" pipes, and hayamee exhausts installed up to the cat without rear resonators; also a custom made intake. It preformed much better than stock. But I didn't like the sound, so I put in new high flow resonators. Now I get a nice deep sound sort off corvette , but not domestic ,almost italian. I'm very pleased. I am now considering changing the piping
from the engine to a high flow cat, because as explained to me the dual pipes from the engine are compressed to half their size to fit in the standard cat; so by doing this I get rid of alot of restrictions.I'm not sure if I should keep the upper resonators by the engine, or start the piping at that point?
Hey sounds good, so the trick is to replace the existing resonators with a high performance resonators, right? Almost having two additional straight through mufflers I guess.
Have you try to drive around in an underground parking structure? I've replaced my factory mufflers with Magnaflow 2.5 inch straight through mufflers, it sounds a lot deeper when starting from a stop sign but still too quiet for my taste so I was thinking of replacing the rear resonators with the resonators made by Magnaflow, which are high performance resonators, until I heard my car in an underground parking strucuture. My car sounded like a beast in an underground parking structure, sounded a lot like Ferrarri.... Only if I drive under tunnell all the time....
Peter~
Peter~
without the resonators it sounded like an untamed beast at all levels , now it kind of reminds me of a Z28 or Z06 big 8 muscle
car at take off up untill 40 mph, I feel an increase in power, it might be the intake I don't know? When I smash down the pedal
and the the car opens up it sounds crazy.
Originally posted by Bean
resonators are different than straight-through mufflers
much different
SC400NYC, what about the sound did you not like?
much different
I've always understood that a resonator is a 'front muffler' usually circular in size with a straight pipe, and a straight thru muffler is a 'terminus muffler' usually oval in size and has a pipe that is usually (but not always) offset. But they both have a perforated straight thru pipe usually wrapped in ceramic/stainless Steel wool/ or fiberglass.
The only difference is that a resonator is usually directional flow, and a Straight Thru muffler is non directional flow.
What are your thoughts.
my thoughts of a resonator is more of a dynomax bullet
basically thin walls; just a piece of piping with a very small chamber over it; it does not restrict exhaust flow too much
a straight through muffler is more of a dynomax ultraflow
its basically a big resonator
much larger chamber around the perforated pipe
Then, using your defination, Bean, I'd say we should only use straight thru mufflers in our exhausts as opposed to resonators.
The Dynomax bullets are almost pointless for street use, so why bother. They are great for racing when you need to drop a dB or 2. Their oval ultarflo's are actually decent for a straight thru muffler.
Has anyone checked out Edelbrocks RPM series mufflers? I plan on getting them for my front section of my exhaust right after the X-pipe. Then replacing the factory rear "resonators" with the Dynomax 6" ultraflows. And ending into a polished Borla straight thru's.
Hopefully it will not be too loud w/o cats.
It'll be summertime before I do it, but I'll post pics when its done.
Keith
Keith
Originally posted by SC400NYC
Did I lose hp as well as sound when I put the resonators back
on? even though they are so called_HI FLO_ "made for 2.5" pipe" ?
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
When I was installing my new exhaust, The guy threre recomended I go all the way to the engine,
because he says there is to much restriction at the cat and suggested that I eliminate the two resonators or little mufflers right after the engine and convert to a larger cat to pass NYS inspection. Has any one tried this or some thing similer or
have any feedback?
have any feedback?
I'd have to agree with the muffler man about the restrictive stock cats located right behind the manifolds.I was going to just replace the two cats with a single unit,use the stock system for a starter system.
