OBX Header...Buy or Pass???
If you aren't into custom modifying, just watch out.
I had an OBX header on my Supra. I modified it heavily to be correct for the car. Once I was done though, it came out to be a nice piece.
![](https://img.photobucket.com/albums/v208/935motorsports/84/header/IMG_0936.jpg)
For this car though, I'm not sure how much it will do for you other then removing the cat and saving a few pounds. That is my goal, I just want to delete the primary cat. My supra only had the main cat, not a pre-cat, and I want my SC300 to be the same way.
If I can find a deal, I'll be trying one out. Until then, I'm not willing to spend $350 on it. Instead, I picked up an IS300 header for $100 used, and will be adapting that.
i have them on right now and i think it definitely helped my bottom end but im gettin a little whistle when i gun it, maybe just because of the more air flow? cause i didnt see any leaks
The general rule of thumb throughout the years in the industry basically is avoid the brand. Be it for Import/Domestic makes. I hope we've helped steer you in the right direction.
i had it on my SC300 for about 2 years, no problems. took the same one out and now i have it on my cressida...still no problems. i suggest upgrading your intake and the rest of the exhaust for optimum gain.
