1jz swap question?
1jz swap question?
i already have the 1j swapped it has beed for awhile now, but i have always ran electric fans well now that the weather is warming up i can tell u that its not gonna cut it! so my question is does the sc300 fan shroud work with the swap cause i wanna go back to the mechanical fan
This would be an engine related question so the proper place for this thread would be over in the PERFORMANCE/MAINTENANCE section.
The SC300 stock fan shroud will work with the 1J. If that Texas heat is really beating your motor up I would run the electric fans and the clutch type fan together. Did your 1J come with the hydrofan?
