biggest cams
been researchin this myself so far all i got is:
"The 1jz 264's that BC is making are the crower 272 small core cams. They mimic the HKS 264's but with more lift to give more power. The Bc 272 will be a little smaller then the original 272 large core cams form Crower because the large core broke 2 engines mine and one other tester because we spit out the shims with .404 lift.. yeah that's a good lift "
t's recommended to use shim under bucket with any kind of cam over 272, but the first thing to upgrade would be the springs and retainers. Valves also play a vital role, as the stock ones wont take the abuse of a high redline that long."
got my info from supramania
did u get the 264 cams cause i ran across this on another site
and this is also an option putting 2jz cams in a 1jz:
http://www.supramania.com/forums/showthread.php?t=55085
and this one has some dyno graphs:
http://www.supramania.com/forums/sho...t=48095&page=3
