This is why you don't buy mods at 3AM.
Old 03-24-09, 08:33 AM
tavarish
tavarish's Avatar
Default This is why you don't buy mods at 3AM.
Hello all.
About a week and a half ago I bought a turbo on a whim for my engine. I knew this turbo was a bit big, but I got it today.
The package was 61lbs, and came in a wooden box that i could only open with a powered drill.
I don't even know what kind of turbo it is, as I can't ID the casting or Assembly numbers.
Here's a few pics:
Looks like a divided T4 flange (hopefully)
Here's a few pics for comparison:
KA24 rod and piston inside the compressor inlet:
Turbo next to a tall degreaser can:
On top of a friend's K20A3:
I do intend on making this work on my 2.5L 1JZ-GTE. The turbo has a 6" inlet, 5" exhaust, and looks pretty decent. Doesnt have much side to side shaft play, and no in and out play. the shaft spins freely, and didn't bind anywhere.
I'm going to do a fair bit of custom modding for this to fit, but i think it can be done on a budget. Don't want to run more than 10-20psi with a quick-spool valve, for fear of compressor surge.
I got it for 145 plus shipping
Let me know what you think.
Old 03-24-09, 08:44 AM
ICONYQ
ICONYQ's Avatar
do you know the specs of the turbo to know if you are able to only run 10 psi range??
Old 03-24-09, 08:51 AM
DIrEctQL
Chicago Lexus Club Moderator
DIrEctQL's Avatar
It's off Cummins truck. Nothing special.
Old 03-24-09, 08:57 AM
Trevstuh
Trevstuh's Avatar
Looks to be a holset hx55 or bigger, look at the holset tag on the compressor side and give back the info on what the tag says.
Old 03-24-09, 09:05 AM
Trevstuh
Trevstuh's Avatar
Ok the turbo you have a is ht3b, they run around a 23-28cm^2 housing, and suppose to be equal to a 76mm turbo, and support 700-800hp.
Old 03-24-09, 09:11 AM
AD_SC3
AD_SC3's Avatar
lol you could suck up small children....I hope you can make it work good luck.
Old 03-24-09, 09:14 AM
tavarish
tavarish's Avatar
Nope, just assumed it would surge.
Lawls. When you deal with tiny turbos all the time, it's a big deal when you can fist an inlet pipe.
Great timing, As youw ere writing this, I found this out. When I get home, I'll find out what housing I have.
I feel much better about spooling this, since people are spooling T88s, which are larger, with a 1JZ. A bit laggy, but nothing to worry about. I think I could get this thing spooling by 4k with cams and a quick spool valve. I'll see if I can find a smaller housing in the meantime.
Old 03-24-09, 09:44 AM
Peter_95
Peter_95's Avatar
woah, that looks HUGE! kinda like a trucks turbo... good luck
Old 03-24-09, 09:51 AM
tavarish
tavarish's Avatar
LOL it is a truck turbo.
Old 03-24-09, 10:02 AM
Trevstuh
Trevstuh's Avatar
I think you could switch out the exhaust housing with a hx40 I'm not too sure so you could spool it quick, but most of holset turbos spool very quick so you may be ok.
Old 03-24-09, 10:42 AM
tavarish
tavarish's Avatar
Some of the diesel guys have trouble spooling it, but their exhaust characteristics are completely different. I think it has a 32cm^2 housing. I think I may just block one side off permanently, or use a quickspool valve to get the desired result.
Old 03-24-09, 03:35 PM
matrixgts
matrixgts's Avatar
man i did not know you can put these on our cars.because at work we have a bunch of old diesel trucks with turbos on them doing nothing.
Old 03-24-09, 03:37 PM
VJZ
VJZ's Avatar
Thats a Holset HX50.
BFT!!
Old 03-24-09, 03:52 PM
Trevstuh
Trevstuh's Avatar
I pretty sure you can switch exhaust housings so you can spool it quicker.
Old 03-24-09, 03:54 PM
DIrEctQL
DIrEctQL's Avatar
For most part those are big turbos and spool isn't too good on those. Get something smaller or if you want big there are turbos with quicker spool.
Quick Reply: This is why you don't buy mods at 3AM.
