Little teaser - You SC400 guys will enjoy this even more!
#32
Actually, the whole assembly does not come anywhere close to the exhaust manifolds. It has nothing to do with the swap actually.
The lines for the hydraulic throwout bearing are steel braided lines, not hard lines, so maneuvering them is not difficult at all.
What I have done is a 90* off the MC and then the line goes under the brake booster etc... and then into the bellhousing.
![](http://img.photobucket.com/albums/v499/redphoenix/Lexus%20SC400/5spp/IMG_6950.jpg)
![](http://img.photobucket.com/albums/v499/redphoenix/Lexus%20SC400/5spp/IMG_6305.jpg)
Anyways, questions on the build!
Was it difficult to place to pedal and run the lines while having the exhaust manifolds right there? That's the only particular area I have concern about, and even more so since I have the S&S headers and full exhaust.
If you could take a picture of that area at your convenience that would be awesome, keep up the good work Matt!![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
-Matt.
-Matt.
#34
Are you doing the hydraulic thrust setup? Sorry if I missed it in another thread.
edit: Found out why lol. Wasn't sure how your adapter setup was supposed to work, but since I see it mates the W58 to the stock 1UZ bellhousing, obviously there needs to be a different clutch setup. Do you just drill a hole in the bell to run the hydraulic lines through?
#35
#36
damn, can't believe i missed this! will be watching this thread closely.. i remember before when i did a manual conversion on my pajero, the R would light up when i put it on reverse..
#39
Ah, from what I had heard you can still see the PRND2L even when the bulbs are removed.
Know what I mean? When you look really closely, or there is light shining directly on it.
(When I said paint, I meant remove the bulbs as well as painting.)
Personally I would try and find the correct 5-Speed cluster and swap your odo over.
