well...
Fusebox Relocation
Battery Relocation
ABS Removal
Trac Removal
Hide all Wires and Lines
setup vacuum line plenum
re-removal of the charcoal canishter
later on planning on replacing
radiator
radiator shroud
new coolant reservoir
new power steering reservoir
Start
Fuse Box Rewire
ABS removed
Garbage!
Once im done im gonna figure out how much everything weights, my cousin told me 100 so thats what im hoping. Dirty engine bay too btw planning on cleaning it once done.
I love it, spools up like the stock twins, still have yet to give it more then half throttle... kinda scared :S but i was getting 20psi at 6k then letting off.
well i am removing:
all of the wiring
abs unit
trac unit
the fuses
abs fuse unit
all of the lines
actual abs
So far I think im at 60lbs with the abs and trac unit and some wiring left over.
My guess is 80 pounds once all is out.
so it spools like the stock twins hmmmm i might have to go with a snail your size i want to go with a T67 but looking for something the spools up quickly are you auto or manual sorry i havent cant remember from your other threads
