TH400 Tranny question (High Horse Power Guys)
Th400*
3 vitesse a place de 4*
7 clutch*
shift kit*
bellhousing 1jz/2jz
Is this a daily drivable transmission, and if so! What kind of work and i seeing for the install? you think it would be a straight up bult up no problem?
its going into a 1991 Toyota Soarer 1jz Gte Automatic? Would i need to get a new drive shaft?
What am i getting my self into!
its a 200$ deal on my end i jsut nede to knwo if it worth it?
7 clutch*
shift kit*
bellhousing 1jz/2jz
For the future can you please post threads in their proper location? This is your second thread I had to move today.
$200 for a TH400 is a steal. I dont know if you've ever been in a SC/Soarer/Supra with this tranny but when you're cruising at highway speeds you can definitely feel the sacrifice. For a JZ block you'll definitely be needing the adapter for it. Im not exactly sure about the driveshaft but I'll go ahead and move this over to the Engine/Performance section to see what the others think.
thanks man, i wasnt paying attention! lol
but ya the tranny is coming from a 2jzgte supra he said im getting everything i need but on my end i jsut need to know the drive shaft!
These guys do. They are pretty familiar with the Supra. Just call them and tell them what you have so they have a general idea of what you're working with. Then they will tell you how to specifically measure it and voila! You have a custom 1 piece with metal spacers instead of rubber bushings that crack over time.
