AHHH so Frustrated, I need some o2 Sensor adapters
Old 03-27-09, 01:17 PM
Sup2jzgte
Sup2jzgte's Avatar
Default AHHH so Frustrated, I need some o2 Sensor adapters
EDIT: I found the adapter I was looking for, you can see a picture in post #11.............I have another issue.
Ok so today has be one of more frustrating days of my life for me lol. I'm not going to go into details and get straight to the issue and the questions.
I bought Autobahn88 Headers from a member on here, but sadly after I took everything apart I realized the o2 Sensors that he sent with the heads have the 1 wire connection and mine are the 4 wires (not the sellers fault, my own stupidity) and the connection on the heads are made for a flange o2 Sensor and mine are the screw type. So what I need to know is where I can get a bracket/adapter or something to make my o2 sensors work?
Old 03-29-09, 10:16 AM
Sup2jzgte
Sup2jzgte's Avatar
The thread is m18 by 1.5mm pitch. The holes are 45mm apart from centre to centre and are 8.5mm diameter. The adapter is 8mm thick.
Here is a picture of the heads, I'm just concerned that this is to thick, what do you guys think?
Old 03-29-09, 12:46 PM
VJZ
VJZ's Avatar
Get that eBay link off there.
Old 03-29-09, 01:37 PM
Sup2jzgte
Sup2jzgte's Avatar
Why, I'm asking a question regarding that particular product. Also unless you are a mod who the hell are you to demand me to take anything off?
Old 03-29-09, 03:50 PM
TurboGS
TurboGS's Avatar
i have the catless midpipe for those headers if your intrested.
Old 03-29-09, 05:07 PM
Sup2jzgte
Sup2jzgte's Avatar
HMMMMMMM how much?
Old 03-29-09, 05:18 PM
93MSB
93MSB's Avatar
you can do 1 of 2 things
1. take the header to someone and have them change the flanges to bungs
2. buy 4wire flanged O2's
Old 03-29-09, 05:32 PM
Sup2jzgte
Sup2jzgte's Avatar
Actually I think I found a flange with a bung welded on, I'm in the process of contacting the dealer to see if the o2 sensor threads will work
Old 03-30-09, 10:23 PM
wanganstyl
wanganstyl's Avatar
If you need a 2 bolt flange to screw in your current o2 you can get that flange if you get a cheap generic o2 at Autozone for a 4cylinder ~94 camary. You could also junkyard it ( the flange only, you don't want a junkyard o2)
Old 04-01-09, 12:32 AM
DrLex
DrLex's Avatar
If you go to any parts store and get a univeral/toyota o2 sensor, it has the flange you are looking for. 2 bolt old style, but a screw in bung for your type of o2 sensor.
OR
Like someone said, just get a couple of o2 bungs and have them welded right on the flange area, so you can screw yours in.
OR
get 4 wire flanged 2 bolt o2 sensors from camry, mr2 turbo, etc, like the other guy said.
Old 04-01-09, 05:04 PM
Sup2jzgte
Sup2jzgte's Avatar
Thanks for all the help guys, I actually found this adapter which works AWESOME.
Now I'm having a HUGE issue getting a gasket between the Federal and first cats the stock gasket does not work.
RedlineAZ
IS F (2008-2014)
07-15-14 09:09 AM
ashtray
03-01-12 05:28 PM
redliner8
09-01-11 10:00 AM
puff
Performance
02-15-11 12:25 PM
riot8088
07-18-05 01:41 PM
Quick Reply: AHHH so Frustrated, I need some o2 Sensor adapters
