93 sc400 timing belt change?
Hi all,
I bought my 1993 Lexus SC 400 new and obviously don't drive it much....It has about 67,000 miles on it and still looks new. It drives perfectly however, I was told recently that I should have a new timing belt put on it for maintenance. They apparently recommend changing the belt somewhere between 70-90,000 miles. I was also told this could be expensive. Since I am pretty handy, could I do this myself? and is there an online pictorial description on how to do it?
Regards,
rcftx
Regards,
rcftx
doing some reading and found this.it is step by step how to do a timing belt http://planetsoarer.com/cambelt/cambelt.htm
Yeah 80,000 miles they recommend to replace it. Time wise is around 8-10 years. It also depends where you keep the car outside or in a nice garage. You need a couple special tools ,but nothing crazy to perform the service. It runs around $900 to $1100 saying if you get the pulleys and the water pump taken care of while there in there.
