Nitrous Install
Old 03-30-09, 09:25 AM
EscapeSW20
EscapeSW20's Avatar
Default Nitrous Install
just got a venom kit from a buddy of mine... wondering if its worth installing on an SC300??? if u got any feedback, let me know!!!
Old 03-30-09, 10:51 PM
EscapeSW20
EscapeSW20's Avatar
its a VCN 500 kit...
Old 03-31-09, 07:44 AM
1siksc
1siksc's Avatar
What kind of mods do you have done to your car? besides that would you be using it for street races or only the dragaway?
Old 03-31-09, 09:16 AM
EscapeSW20
EscapeSW20's Avatar
just got basic bolt ons...internals all stock! looking to use for for streets......
Old 04-01-09, 12:02 AM
97RSPSCTT
97RSPSCTT's Avatar
yeah i'd also like to know what kind of kit is best for the 300 w/vvti, wet or dry and what hp shot would be best for bone stock motor. or if its even worth doing
Old 04-02-09, 09:34 AM
EscapeSW20
EscapeSW20's Avatar
i might just put it up for sale!!!
Old 04-02-09, 05:54 PM
dohc3ltt
dohc3ltt's Avatar
I'm running a 150 shot on a stock bottom end ..I think you'll be fine with a wet kit.
Old 04-02-09, 06:17 PM
SC300_704
SC300_704's Avatar
but yours a tt, the compression is lower and has more fuel than the n/a which means you could have a bigger shot..but i thnk a 75 shot should be safe for a bone stock SC300.
Old 04-03-09, 05:52 PM
dohc3ltt
dohc3ltt's Avatar
I run a NA block with a TT head...
Old 04-03-09, 06:15 PM
IOWNALEXUS
IOWNALEXUS's Avatar
Compression has nothing to do with nitrous, you can run it on a 9:1 motor or 14:1 motor, on a wet kit extra fuel is supplied by the nitrous nozzle or a dry kit raises the fuel pressure to compensate.......I would think a 100 wet shot should be safe if your car is running properly and well maintained, anything over that and i would advise a larger fuel pump,colder plugs and backing off the timing. Even the 2JZ GE block is very strong, there has been many people well over 600rwhp on a stock bottom end.
Shadowen
02-27-12 07:09 PM
JZA80MHU38
03-21-07 02:16 PM
LyFeWoRx
16
10-13-06 09:56 AM
jgscott
01-01-06 07:49 PM
MikeGS4PE
03-29-01 05:31 PM
Quick Reply: Nitrous Install
