Both Door Handles on Passenger side not working How do i open the door?
The interior passenger side door handle has been broken for a while now i went outside this morning to unlock the door from the outside now that door handle wont even work!!! How in the !@#$ am i supposed to open the door?!!! lol
This sucks when you and your girlfriend has to slide in the drivers side before you get in!!! lol HELP!!!!
Im having the same trouble. The clip that holds the bar from the handle down to the lock broke. You need to replace that. I still havent found the problem with the inner handle. I can still pull it but it wont open the door
Jonny
that's about right, if both quit working then your only option is to try and get in enough pull the release cable without damaging your panel as much as possible, or do like some have and cut the door panel open and buy a new one..
I would take off you door panel and check to see if that rod is broke! Mine is and I can't open my passenger door from the outside, I got to either get a new piece or figure out something.
mthibode
07-29-15 03:40 PM
bagyo
SC- 1st Gen (1992-2000)
06-28-13 03:29 PM
