Just Got My Clutch Today
My GripForce stage 2 clutch just came in today for my w58, and I have already found that the torque specs are 36 ft/lbs flywheel and 14 ft/lbs pressure plate, and I also know to turn another 90 degrees for the flywheel and to go a little higher for the pressure plate. What I can't seem to find is the torquing order for the bolts. I know that in general, you start from the middle and work your way out in a criss cross fashion, but if any one has an actual torquing order that they found, I would love to see it. Trying to get the car ready for drifting this year.
Congrats on the new purchase. Ive never heard of a Grip Force clutch before. I'll have to look them up. As far as torquing order just go in a star pattern like you were to torque a set of lug nuts on your wheels. Once you're done with that you do a quick circle check and then continue with the 90 degrees.
