Easiest way to swap in a TH400 trans?
Just wondering if anyone has a good comprehensive parts list for swapping in a chevy trans for the SC3?
I know there is a couple routes than can be taken such as adpter plates, tq converters, and so on.
So what is the general consensus?
So what makes the swap easier and less of a pain to do
thanks in advance
thanks in advance
I still have yet to do the swap but here is what you would get if you got the BL complete th400 conversion.
* BL Built TH400 - Now with Neal Chance Internals
* BL MKIV Supra Bell Housing Adapter
* BL Non Lock-Up Torque Converter
* 3,000rpm Foot Brake, 6,600rpm Transbrake
* BL Driveshaft CNC 6061 Aluminum Transmission Mount
* Digital Speedo Adaptor
* B&M Quick Silver Shifter
* Lokar Stainless Steel Dipstick
* Energy Suspension Polyurethane Transmission Mount Bushing
* B&M TH400 Shifter Bracket
* B&M TH400 Shifter Cable
* Six speed Console
* Transbrake Valve Body
Here is a great article for doing the Tach Adapter
http://www.floridasupras.com/showthread.php?t=661
If i find out anything else i will definitely let you know
* Six speed Console
there are a couple guys in our state running in the low 11s with them in supras, and have been for over 6 months, sad part is it is sooo cheap to rebuild a turbo 400 trans, max a couple hundred dollars in parts
1siksc
Performance & Maintenance
33
09-26-10 12:29 PM
