question regarding 1JZ swap
hey guys, so pretty much think i screwed my engine, now im just gonna say screw repairing it and get an engine swap.
my question is the 1jz is a direct swap into my sc300 correct?
does it matter what car the engine came from or are they all a direct fit.
also if i get the complete swap engine/ecu/tranny etc thats all i need right? will it work with my stock rear end?
all i really need to do is get the jdm harness extended correct?
ALSO please point me in the direction of any and all threads to help me out before i start this swap in my garage
EDIT: Whats the difference between a supra 1jz and a soarer 1jz... how much trouble is it to swap the supra 1jz into mine cause if found a real good deal on one
Former Sponsor - Cancelled
It does matter what 1JZ you get. The 1JZ Soarer and Supra will bolt right in (rear sump oil pans). The Chaser 1JZ will not, you would have to swap the oil pan.
If you get a Soarer engine with complete harness, then that harness is *close* to the SC300. Most people just extend it outright and live with what doesn't work. (Personally I think that's a little sloppy. If you have you wiring done by us it will be plug and play, everything will work, and it will have a warranty).
If you get an engine set from a Supra or a Chaser, then it's going to be a good bit more wiring work even beyond the Soarer harness, because those harnesses are TOTALLY different. But it's only a couple hundred bucks of wiring work so if you can get a good deal on a Supra 1JZ, go for it.
-Doc
-Doc
I've heard various different things from different people, such as the ABS, the Airbags, the Starter needed to be jumpered, etc. That's just the evident things, the pinouts for the Soarer interior plugs are a good bit different than the SC300, not to mention that the SC300 pinouts change from year to year. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Plus most people probably solder their connections which is, uh... a little less reliable than mil-spec crimps![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
But hey, like I always say, some people like wiring and some people don't. If you like wiring and want the challenge, go for it. If you like having a professional do work like that and having a warranty, then send it to us![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Personally, I see the advantage in having a professional do work for me. For example, I could sit down and figure out how to do my own tax returns. But I don't really enjoy that and I know that a professional will probably do a much better job, so I pay an accountant to do that for me.
-Doc
-Doc
im going to speak with the shop today dr. tweak and probably get my harness sent to you, i would like all my functions to work haha
so what exactly would i need to send into you??
Also REALLY BIG question, this motorset is with the auto tranny from a supra it will fit right up with my sc300 right? or is this something ill have to use my stock a340 auto tranny with.
i know the 90-93 supra is shorter than the sc300 but will the auto fit right in my 93??? someone please this is pretty much the last question i need answered
so your saying NO to the supra tranny fitting into my sc???? im going to have to use my stock a340???
Ipolo69 im re-reading your post and it looks likes your saying for the supra 1jz tranny to work in my sc i have to swap the tailshafts from the a340??? as well swap some sensors from the a340 to the new 1jz auto?
-Doc
