gte dyi??
only thing is i didnt watn to deal with the wiring, so dr tweak is the guy to go to unless you want to figure it out. nobody wants to give up an aristo wiring diagram unless you want a US harness
aristo is to short and totally wrong, only thing that plugs in is the ECU, you then have to run all your own body plugs, you cut the body plugs off of the GE harness and put them onto the aristo. if i had both harnesses i could probably do it. also need to cut the EFI plug at fuse box in engine bay and put it in the harness to switch on the ecu.
I heard once you cut off the aristo body plugs, most of the wires on the SC body plugs are the same colors, so you just connect most of them, but there are like 10-15 that are different. I think you have to pin a couple too. A buddy of mine wired up his aristo harness himself.
just need, AC, thermostat for heater core, steering rack, water temp to cluster, tach mod, power to ecu. its actually very simple. i was just so sick and tired of working on my stupid car i payed dr tweak
slappy96
Performance & Maintenance
07-24-08 03:23 PM
