How do I remove the 150 AMP ALT fuse on sc400?
Someone blew my 150 AMP alternator fuse on my sc400. I went down to the dealer and bought a new one. Opened up the fusebox under the hood and removed the battery so as to access the bolt that holds the 150 AMP (red) fuse in place. Problem is... I can't see how I am supposed to get a socket over the bolt that is holding this fuse in because of the plastic box that all of these fuses sit down inside... it blocks a socket from fitting over the bolt! I tried using a screw driver to unscrew the bolt but it started to bend the metal and ruin the X in the bolt before it would budge.
Please help as I am desperate to fix this before I leave on a long road trip this weekend!
Thanks, Swbrannon
Thanks, Swbrannon
swbrannon
Performance & Maintenance
04-15-09 05:37 PM
