Car is running like crap after putting in gumout fuel cleaner.
After I put in the fuel injection cleaner my car runs like crap it idles at 500 and shakes bad. I also have a ghost in my coolant system as I don't know where my coolant is going but sometimes while driving my car temp gauge goes up but than back down. I check the coolant and my resivor is dry and the radiator is low too, I thought it would be my fan as one of the blades is missing a quarter size piece to it, but the fan has been like that since I bought the car. Yesterday the cel came on I just reset the ecu and so far the light haven't came back on, I don't know if you can jump the cel with a paper clip like you can do a honda.
You might have fouled out your plugs loosening all the dirt out of the intake system or the valves. Its like using sea foam the mother of all intake cleaners lol. It loosens all the carbon and dirt buildup and it sits on the plugs and burns. Don't have the correct spark or delayed spark then it runs like crap. You also might have a head gasket leak because your loosing coolant and you didn't mention it leaking on the ground. Smell your exhaust while it is running and see if it smells sweet. If it is your burning coolant in the exhaust or on your spark plugs fouling those out. Run the car till it warms up in the driveway and check the ground for leaks. Monitor the fluid level in the reservoir for any changes. Check the radiator cap to see if there are any bubbles coming out and if there isn't air in the system already you have a issue. If no leaks are found and the fluid level has gone down you might want to do a compression test on the block. You can reset the ECU with a paper clip under the hood there is a diagnosis connector. Search for which pins you need to reset the computer.
JBrewster
08-19-08 06:57 PM
