SC400 Power Loss after Muffler removal???
Sounds great without rear mufflers however I can feel a power loss...Guess the back pressure is needed...hmmmmI think the SC400 Likes plenty of back pressure...Is this the case/
so whats the difference between removing the mufflers versus removing resonators???I read lots of ppl hear remove the resonators...Dont see what the difference is? Nice deep tone without mufflers..Also what replacment type mufflers would u all recommend....Bullet style or stock style? Brand/
i have a cutout (bypasses mufflers) and love the sound of the raw 1UZ V8...only wish it was a little louder, less restrictive, etc...teehee...actually without the turndown tip I have on it, it is horribly loud...but the turndown makes it deeper and have a better sound/tone. i assume yours sounds about the same without my turndown. but yeah, the only thing i don't like is the loss of torque from less back pressure. i really need an electric cutout.
resonators don't cause back pressure to my knowledge or very little if any. they're just supposed to lower the sound, i think. i deleted my resonators a long time ago. it's not a huge sound difference between resonators and no resonators; very slight. Removing the mufflers will make it a lot louder than removing the resonators. Mufflers on the other hand do cause some back pressure.
as far as mufflers go, magnaflow is the popular choice, moderatly loud and pretty deep and for a louder, meaner sound, flowmaster is supposed to have a nice sound to them.
I have unbolted my mufflers before, and now run it with mufflers and deleted resonators. No mufflers is definitely a lot louder than no resonators, but no resonators gives it a more throaty tone.
I would maybe try resetting your ecu and give it a good couple of 1000-3000rpm runs under wot to let your ecu know that it is now dealing with less back pressure.
I don't consider an "X" or "H" pipe to void the "true dual" statement.
An X-pipe contains 2 true pipes that have been shaved off at the center of a bend and then welded together at those points:
If It's made up of 2 (not always seperate) pipes all the way from the collectors to the tips, then I consider it true dual, no matter how those pipes are connected.
Now consider a setup like this muffler has:
A setup like this Dynomax Ultra-flow has inside would violate the "true duals" because the exhaust pulses will share a single pipe even if its just for the length of 4 inches. The pulses will be crammed into the diameter of one pipe and will not be able to maintain the same velocity, they will try to slow down, also known as: Back-pressure. The former X-pipe design is far superior(and true dual ) because it maintains the diameter of the inlet pipes as much as possible
If, at one point in the exhaust, pulses share a single exhaust pipe, then it isn't a true dual setup. At least that's the logic behind my definition.
BTW, Congrats on your ASE. cert, I'm hopefully getting mine in Engine Machinist (M1) this summer
A setup like this Dynomax Ultra-flow has inside would violate the "true duals" because the exhaust pulses will share a single pipe even if its just for the length of 4 inches. The pulses will be crammed into the diameter of one pipe and will not be able to maintain the same velocity, they will try to slow down, also known as: Back-pressure. The former X-pipe design is far superior(and true dual ) because it maintains the diameter of the inlet pipes as much as possible and therefore
LoL, well pointed out bro, even though i still dont believe they are true dual
My definition is an exhaust system that i can put my hand on one of the pipes and check bank1 and put my hand on the other pipe and check bank2 while knowing that any A/F, temp, pressure tests i do pertain to that bank.
