a340e Transmission Pan....?
Hey, I was wondering if they make a deep pan for the a340e to hold more fluid. Does anyone know of such a product? are the pans on the 2jzgte transmission the same as the 2jzge transmission? size comparison?
ABout the two pans, judging from my experience with the MKIII the NA and turbo trans pans are identical...the only difference between the two trans are more beef in the drive line, the case and pans are the same, i dont see why this would not apply to the 2J stuff as well.
I found this morning about the pans again. You can use a 99 Lexus gs300 trans pan an it bolts on to the supra tt trans. The pro about this is you can run more fluid in which helps dissipate the heat quicker. Well I ordered one through champion for 90$ an to me thats worth trying to help cool down the trans after running it hard on the streets. Yes i also have a huge aftermarket trans cooler also so that helps as well.
Bocatrip
10-18-18 02:57 PM
