Single Turbo JDM 2JZ-GTE v. Single Turbo US 2JZ-GTE
If one goes single turbo on a JDM 2JZ-GTE, would there be any difference in power as compared to a single turbo'd US 2JZ-GTE, given that the single turbos in each case is identical?
mechanically, the only difference between JDM and usdm longmotors is the intake cam.
with a single turbo; you should be replacing:
ecu (or adding piggyback), injectors (usually- unless a puny turbo), exhaust manifold / piping.
the usdm longmotor will make slightly more powert due to the more slightly more agressive intake cam - 224deg vs 233 deg.
http://mkiv.supras.org.nz/specs.htm
Chicago Lexus Club Moderator
97-SC300
Performance & Maintenance
24
11-04-15 08:50 AM
Htowncory
Performance
07-11-12 10:00 AM
