My Aluminum 1uzfe Flywheel Does Exist.
looks like what i want to make but with insert 221101 so its a 10.5 inch surface with a mustang pressure plate then use any 10.5 inch disc for whatever trans is being ran.
Good luck fitting that into the 1uz bellhousing, i wanted to go that route with the 3ur flywheel but it wouldnt fit in the 3ur bellhousing witch is a bit larger then the 1uz. despite that i can get all the grabbing power i need from the clutch design with out the added mass.
Im working on swapping the 1uz out for a 3ur, i guess if i do that ill have to change my sig to "08-10 Toyota Tundra with mk3 supra body swap" or somthing like that.
Still rocking the auto trans? dont want a manual?
Studiogeek
Performance & Maintenance
05-17-15 05:07 PM
KahnBB6
14
06-02-13 10:07 PM
deruvian
07-07-07 02:14 PM
