Clutch Won't Disengage on Turbo SC300, Please Help!
okay folks heres the issue you guys are having
the yoke that mounts through the pressure plate has a lip on it right after the where the snap rings go into which is what holds the assembly together , the lip on the yoke snaps off and releases the rings so the assembly stops moving as one , you will see your slave moving , you will see fork moving , but if you shine a bright light up into the access panel you will notice the yoke does not move with assembly
ask me how i know this , it happened to me once already , and yes doing the same thing , trying to do a sustained burnout/lanuch and it snapped the lip right off the yoke
its another weak spot on the r154, yoke issue and 1st gear thrush washer= not good for strong sudden lanuch when you got power so hence i do not 1st lanuches , strickly rolls from 2 and up
I will be picking up a new slave today and using the 1/4 extended rod I made. I also adjust the pedal a little bit which brought the feel back to it. I already checked the pressure plate bolts after your last update and they were fine. Thanks for all of the help and I will keep this thread updated also.
scsexy
Performance & Maintenance
01-03-17 05:54 PM
baodalazi
SC- 1st Gen (1992-2000)
03-21-11 10:54 AM
