Help with AEM FI/C tune
I just finished my install of my XSPower turbo on my 97 SC300 5sp and today finished the wiring and plugged the AEM FI/C in but car won't idle for more than a few seconds and shuts down. When I plug the bypass harness in, the car runs fine.
Anyone have any suggestions?
The only map I used was the base cal file that you get when you install the FI/C tuning software and uploaded to my FI/C unit. I didn't change anything and just wanted to see if it would run with everything set at 0.
Do you know of a base calibration that I can download for my SC300?
My turbo is set at 9 to 10 lbs of boost and I'm using the stock fuel injectors. Everything else on the SC is stock.
1badsc
Performance & Maintenance
10-31-07 05:12 PM
trd4life
04-02-05 02:05 PM
