looked underneath the car and oil pan is soaked
Here's an update... I took the plastic cover off and sprayed the whole engine with the hose and degreaser and turned the engine on. after everything dried I looked underneath the car and I saw a little oil seeping out from right below the LOWER PULLEY. Does anyone know if this is a main seal or what part is this leaking from? I checked beneath the car and no oil was really dripping, I dont know why all of a sudden it stopped when I just added 2 quarts of Oil and it was completely gone. I poured 1 more quart of oil in and after a week the dipstick still shows it at the same spot. I haven't been driving the car - so maybe it only leaks when I drive the car??
Dude I think you are over filling your car with oil, dont just blindly add oil it is going to make things much much worse. I have had the same leak for some time now and I have not lost anywhere near a quart of oil let alone 2 quarts. IF you are loosing that much oil it would be on the bottom of your splash plate.
It's leaking next to the LOWER PULLEY next to the small hole (what is that hole anyway??) I'm assuming this lower pulley is the crank shaft pulley? This is just a Crankshaft Pulley Seal Leak correct? Because a Front or Rear Main Seal Leak would be from the side wouldn't it? I'm thinking I just need to buy a new Crankshaft SEAL that goes around the pulley to fix this leak....Here's a pic
![](https://i230.photobucket.com/albums/ee72/greyblitz/IMG_0918.jpg)
Just 3 questions
1) how much bolts is there or where to see a Diagram or Schematics to show how to remove this Lower bottom pulley?
2) After the Crankshaft Pulley comes off, what else needs to be done to replace this seal?
3) Just making sure, this isn't a Front or Rear main seal, is it? Because if it's dripping right in the middle and I think it's because the Seal is broke & just needs a new one.
Thanks for any help!
Just 3 questions
Just 3 questions
Just 3 questions
Was it the crankshaft seal?
hmmmm I'd rather no get rid of mine just yet. I have the time to do the crank shaft seal but if I have to take that many parts off I might as well do the water pump and timing belt, idlers and tensioners. It seems stupid to me to put the old bits back on if I have to replace the crank shaft seal and have the engine stripped back that much
I don't want to take that much off it and find that it isn't that seal. That's why I was wondering how Ace got on?
Here is one on replacing the front crank seal
If you need to see what to remove prior to the crank seal have a look on lexls page
Mine is now apart and I'm waiting for the timing belt parts to arrive
Good luck
Thanks for the response that is everything I needed to know. Not the news I wanted to hear but at least I know the steps I need to take to tackle this issue now. My timing belt and a number of other routine items need replacing anyway being an 18 year old car with a 115k and never had them done. I guess I will be adding this to the top of the list good luck with your car.
bdpride04
10-31-17 12:59 PM
bguild
GS - 1st Gen (1993-1997)
14
07-19-07 06:29 AM
