Greddy BCC on aristo motor? possible?
Old 05-09-09, 10:08 AM
tampa mike
tampa mike's Avatar
Default Greddy BCC on aristo motor? possible?
friend gave me a greddy BCC sw20 from his MK4 supra and I was wondering if it is possible to use it on a JDM MAP sensor motor?
Motor is an aristo, I cant seem to find any wiring for it.
original wiring uses TPS signal to fool the MK4s turbo pressure sensor, which in our case is still a turbo pressure sensor but it is our MAP sensor as well.
anyone ever wire one in with any luck?
Old 05-09-09, 02:36 PM
ucfa4
ucfa4's Avatar
You could look it up on google. It should be the same install as a nonvvti
Old 05-09-09, 07:16 PM
tampa mike
tampa mike's Avatar
the JDM motor is strictly MAP sensor based, not only for engine load/fueling but boost pressure limiting as well.
The BCC ties into the TPS and uses its signal to reduce the voltage to the US MK4s "turbo pressure sensor" which is a MAP sensor but only for the turbo pressure.
On the JDM supra and aristo, the "turbo pressure sensor" is the vehicles MAP sensor.
I saw some articles about a VFCC, and maybe somehow using the HK$ FCD
Old 05-12-09, 07:57 PM
tampa mike
tampa mike's Avatar
anyone else?
Old 05-12-09, 08:38 PM
slappy96
slappy96's Avatar
Not the definitive answer, BUT I have not heard or read anything about the BCC that relates to the MAF. All wiring and discussion seem centered around the MAP/Turbo pressure sensor on the intake mani.
Good read
http://www.mkiv.com/techarticles/bcc...GReddy_BCC.htm
Old 05-12-09, 10:17 PM
1sxyrxy
1sxyrxy's Avatar
i have the SW20 on my aristo swap. only one that works. wire it up the same as a supra and same voltage too.http://mkiv.com/techarticles/bcc/bcc_install/bcc.htm
Mattyp
12-15-17 03:47 PM
slickster9
10-11-16 08:49 AM
kinch09
SC- 1st Gen (1992-2000)
05-19-11 06:42 AM
nnnickkk
SC400 / 300 Classifieds
08-14-10 03:45 PM
gotparts?
Performance
06-29-07 06:27 AM
Quick Reply: Greddy BCC on aristo motor? possible?
