15PSI -- Stock 1JZ versus 2JZ
Old 05-10-09, 01:03 PM
cavette
cavette's Avatar
Default 15PSI -- Stock 1JZ versus 2JZ
What are the expected horsepower numbers one can expect from:
(1) 15 PSI -- everything else stock (twin turbos, injectors, etc.) on 1JZ-GTE; and
(2) 15 PSI -- everything else stock (twin turbos, injectors, etc.) on 2JZ-GTE (JDM Aristo)?
Old 05-10-09, 04:25 PM
5sp_jzz30
5sp_jzz30's Avatar
15psi on a stock 1jz turbos is not advised so dont try it.
15psi on 2jzgte aristo is stock....so look up what that motor makes stock(about 280hp, thats the same as the jdm mk4 supra)
Old 05-10-09, 06:03 PM
lemmiewink
lemmiewink's Avatar
15psi stock? Maybe with a freed up exhaust with the wastegate not being able to release pressure soon enough. It should be, at the most, 11.5 psi. The stock boost cut is near 15 psi I believe.
At stock, the jdm makes a pessimistic 280 hp to the crank. At 15 psi I would guess around 340whp. Which is a low guess. Either way I don't think the stock 1j will match it with the same setup for both motors.
Old 05-10-09, 06:23 PM
cavette
cavette's Avatar
I guess Aristo 2JZ-GTE stock with boost turned up to 15 psi is the way to go! At around 340 rwhp, that would be 400 hp at the crank, and that's great for stock with turned up boost and a tune.
Old 05-10-09, 06:29 PM
nate579
nate579's Avatar
I have been running 15 psi for about 2 years now, with my 1jz. And the turbos so far has not failed. Will be upping the boost 1-2psi once I free up my exhaust and add some 272 cams. Delamination of the turbos will happen at some point, but till then. Having fun. But I agree caution should be thrown to the wind. I have a single on stand by but don't want to switch until I need too as opposed to want to. The twin low rpm spool is addictive.
Old 05-10-09, 06:55 PM
tavarish
tavarish's Avatar
Well, at around 16psi+ untuned, I made 313/320 on my 1jz. (I hit boost cut)
Ar 18 psi, my friend in an MKIV supra made 352/360 on a 2jz. We have similar mods. I'm thinking he would be around my power level, plus or minus 20whp at the same pressure.
He was USDM though.
Old 05-10-09, 10:07 PM
cavette
cavette's Avatar
At 15 psi, what do you think you are making in terms of RWHP?
Old 05-10-09, 10:49 PM
nate579
nate579's Avatar
My my dyno now it at 270, but i have stock dp and exhaust. The SC is currently in shop going with a upgraded exhaust turbo back system. 3". Also will install 440cc injectors with fuel pump. It will be tuned with Apexi NEO, hoping for 320 rwhp. This is my daily driving ride so reliability is a issue. I am considering getting the turbos upgraded to steel. There is a few people on here pushing there twins to 20 psi, but they are very ineffecient and will fail eventually. Kinda want mine to kick the bucket but they have been the most reliable thing on the engine. Everything else needed replacing, waterpump, fan clutch, power steering (fixed). Differential kicked the bucket.
Old 05-11-09, 02:03 AM
$C300
$C300's Avatar
Stock fuel cut it set at 13psi, i ran the crap out of my twins at 15psi, i even did 2 passes at like 17 psi did not have a prob, i dynoed 258 at 15psi at a 10.0 afr (all i had was FCD, Boost controler, intake, and 2 straight trough mufflers with factory resinators) this was with the factory auto and intercooler.
Old 05-11-09, 06:19 AM
nate579
nate579's Avatar
I have a FMIC installed. I still hit boost cut event with a BCC installed and tweaked. Usually it tops out at 16-17 psi, especially on a cool day. I think lowering boost to 14 will help. If I can get 40-50hp more I will very happy. I don't do midnight street racing or tracking my SC. So 500+ hp doesn't interest me. But I do like the look on a 350z, G35 or Mustang when they are trying to beat me to a exit. . My twins start spooling at 2800 rpm and at full boost @ 3300-3500. No matter what there is no single out there that can match it in negligable lag department with everything being relative, the twins were never designed to make power on top end either. Because once they blow I have no choice but to go single but again my goals will be in the 400hp range. I already purchased the manifold kit from driftmotion.com, sitting in the trunk.
Old 05-11-09, 01:48 PM
ucfa4
ucfa4's Avatar
The 1j performs good under 15psi but not as well as a 2j
Old 05-11-09, 04:21 PM
rykwebb
rykwebb's Avatar
13.5lbs, 340whp with all the 'fixins' in my sig....but without any of that stuff, the 1JZ will run between 315-320 at 15lbs.
A point should be made that WITHOUT any BPUs, 15psi shouldn't be attempted, its like riding without wearing your seat belt your whole life and then bam...you have no legs because you flew out of the cockpit.
Old 05-11-09, 04:56 PM
RyanV
RyanV's Avatar
Check supramania.com, they have alot of 1JZ performance information.
Old 05-11-09, 05:13 PM
nate579
nate579's Avatar
LOL....But True. I would also say take your time and do everything. BPUing a 1JZ can be very satifying without breaking the bank. But like everyone said, eventually you are going to want more boost then the stock twins can provide you.
Old 05-12-09, 10:17 AM
F4A22
F4A22's Avatar
Mine was holding 15 lbs until a spark plug change now it creeps close to 17-18.Doing the math on my 1/4 mile times it estimated the car at 320ish with boost cut.I say 320-340 whp.Jdm 2JZGTE Auto.
Quick Reply: 15PSI -- Stock 1JZ versus 2JZ
