Ordering Fidanza flywheel and clutch kit.
About to order the Fidanza flywheel and exedy oem replacement clutch kit. Just wondering if ill need any special tools or if theres anything i should pick up to make the job easier. Ill be doing this in my driveway with jackstands...
if you want to make it quick then take off the exhaust in one piece. disconnect from the header and drop it. i did it alone. much easier with 2 people though.
2 days on a lift. i did mine on a lift in less then 5 hours for the whole job not counting the flywheel resurfacing time. i started at 3pm one day. took everything off and gave the flywheel to get resurfaced. picked it up in the morning and put it all back together before noon.
So you don't have to take the exhaust off? I've heard from everyone that has done the job that you have to. And whats PB blaster? Thanks 5sp_jzz30 but someone i know from toyota is sending me all the manuals fo FREE...
Tools: 3/4" socket set, 2'-3' 3/4"extensions, 3/4" swivel adapter, and a friend (from what I remember) PB/ or WD40
take center console off, remove shifter, lift the car as much as you can (assuming you are doing it in your garage),Pull exhaust off, I removed the full drive shaft started at the differential then the center piece, Disconnect the speed sensor and I forget what else was there, spray down all the bolts with pb/wd40, go get food/drinks, remove the bolts, use the long extensions for the top bolts (this is what took me the longest to do I used a jack to tilt the engine making the rear of the engine go down) Once you get those it's easy. I might forgot some steps.. it's been a while.
Bleak
SC400 / 300 Classifieds
10-08-13 05:55 PM
