Need Help. Oil Pan Question.
You'll need to take the GE upper and lower pan along with the oil pick up and put them on the 1jz. Also you have to tap the GE upper pan and drill the hole out for the oil return for the turbos.
i found it quite easy just need a big drill bit to match that hole, and drill the 2 holes almost as big as the 1jz flange bolt holes and tap them but dont drill those 2 holes all the way through. would also recommend using a tq wrench when you get to the part of tq down the #1 oil pan ( the bigger one or upper one) gonna need black RTV
Golden95SC
SC- 1st Gen (1992-2000)
12
05-31-15 07:34 PM
