sc400 oil filter help
Banned
So the first time i had to change my 400s oil was a nightmare, cant even remember how i did it. Well this is round 2 and its worse then before. Lets see the oil filter has tubes running in front of it and below it so getting any kind of twisting motion is impossible because you run into the tubes. I've been trying to remove it for the lsst 5 hrs and now my filter is half crushed It just wont come off. I'm twisting it counterclockwise is that correct? Am i missing some kind of secret? Cuz this is insanely hard.
1JZ Single SC400
It shouldnt be that hard man. I am sorry for all the mass nightmare you have had. The 2 lines that are in your way is going to the bottom of the radiator, I believe? Mine move alittle, enough to clear my hands to get in. I had to cut a larger piece in the plastic shroud, first, to get a pair channel locks around the filter, but never had a problem like you are having. I would say take your time, but it seems you accomplished this hours ago. :-) If you have destroyed your filter, try prying a flat head screwdriver through the whole filter, as close to the base of the filter, as you can, this is to assure the strongest part of the filter, and turn it slowly counterclockwise. The base part is where it mounts to the car. But be careful when you do! Thats all I know what to do. Good luck and keep us posted.
Banned
So i finally did it, i had to jack up the car and remove the wheel. Then remove a few screws to remove that shroud. After that i used one of those strap oil filter wrenchs. But even then it was "that" easy, its not 2jz-ge or even 5s-fe easy. You still have you wiggle it in the right position because of those pipes. Plus after like 1/6th turn you need reposition the wrench since the pipes block you and the wrench doesnt racket. Also now i know you have to remove the oil filter at the base since the rest of it is hollow and crushible.
Here is a pic of my old oil filter.
monkey nuts
1) place nut in narrow-mouth jar
2) monkey grabs nut
3) monkey cannot get hand out, but won't let go of nut!
You are the monkey, filter is the nut covered in burning-hot motor oil.
You seem to be suffering where others are not.
https://www.clublexus.com/forums/per...-a-breeze.html
Congrats ...
I still don't understand why you had to remove the wheel. The hardest part of the SC400 oil change (for me) is not spilling oil on the valve covers after all the "hard" stuff is done.
Banned
to get more leverage on the fuel filter. Once i got underneath the car it took me a few min to remove the filter. For the top i wasted a few hours. Maybe my 400 is special but there are a ton of obsturctions. Pipes infront of the filter, more pipes underneath it and this metal bar between the filter and the radiator.
Newbs haha. 858 posts and this is the second time you have changed your oil by yourself you serious? Sound's like your a forum junky to me lol. Try a IS300,GS300,second gen ES,GX470,or LX570 then come talk to me about how hard it was. Its the best on 300's when the intake is hot too. There is really only 2 screws your supposed to remove pull the plastic back and pull the filter off. Oil pliers are very helpful if someone used vise grips to put the filter back on. Jack the drivers side of the car up 14MM wrench drain oil and then remove filter. Easy breezy.
Banned
If you read post more carefully you would have realize this is the 2nd time i changed the oil on the sc400.
Then if you read my other post you would have seen me mention the 400 isnt as easy as a 5s-fe or a 2jz-ge. Which implies i have worked on other cars.
And no their arent 2 screws to remove the plastic. You need to remove atleast 3 on the side and a few more on the back. But then again my plastic is ripped in the back so didnt count how many i needed to remove their.
So no 1uz-fe not easy as breeze. 5s-fe now thats easy.
Was this really necessary? The guy's already been through a tough time ... and now you heap more on him.
OP, can you post some pics of the underside of your engine so we can check if your car is different?
Oil Filter
