what manifold are you using(2JZGTE)
About to purchase a manifold to start the single conversion on my car and was wondering what manifold you have.
I have looked at the cast manifolds but not sure if my turbo will fit due to compressor size(bullseye S372R)
I have looked into the drewgo and am waiting on a PM back from him
also on another note, I have seen tons of guys running the standard OBX/SS-autocrome type manifolds, but not sure which ones are better than others(someone said that one version ***** the turbine flange a little to help with DP clearance)
so some links and or pictures would be very greatful
The R cover is big....I had to grind down part of the compressor housing to fit the regular cover on a boost logic manifold. I also had the manifold modified for dual wastegate, for the dual scroll BW.
i just got off the phone with cxracing. they said they are designing a new manifold that shoud be out in 2 monthes to adress compressor housing clearance problems. i was curious and called b/c i have a t70 and didnt wanna waste my time buyin something that wouldnt work
