Head bolt torque 2jzge 1992
I've searched and I can't seem to find the head bolt torque on a 1992 sc300 2jzge motor non turbo.can anyone help a fellow 2jz owner.thanks in advance.
P.s. I found a few web sites that says 25ft,+90,+90.this can't be true.iam not sure if it's a 2jzge 1992 motor
www.clubna-t.com
In the SC300 technical section, there's a factory service manual that tells you all the tq specs for a 92 SC300. There's also one for a 95 supra.
Stock head studs- 34 nm or 25ft lbs then mark the front of the bolts. Turn them 90 degrees in the numerical order- you do have that part right? Then retighten the bolts an additional 90 degrees and make sure the mark is now turned to the rear. The bearing cap bolts are 20nm or 14ft lbs. But you have to do the pain in the butt loosen and retighten thing. Timing belt cover is 8.8nm or 78in-lft. Let me know if you want my manual or specs for the ARP's.
Ummm- anyways...how about you hit me up at HYJAXX@aol.com and I'll hook you up with my manual pdf style. Peace out!
Post the ARP Specs please, I am installing them in my 1JZ soon and would like to ensure i have everything right
also here's a thread i started for torque sequence, etc.i believe 1jz / 2jz-ge/gte are the same for head studs. hope it helps
https://www.clublexus.com/forums/per...-sequence.html
davekuhar
Performance & Maintenance
08-03-10 06:47 PM
