need advice on sc300 auto swap
ok guys i wanna swap a 1jz or a 2jzgte into my auto sc 300 which swap is more a direct swap ? does the 1jz bolt right up? about the 2jzgte? i still wanna run my ac and stuff to the car will still be a daily just want a lil kick? can i retain my auto tranny? i wanna do this within the next month
Banned
1jz is a more direct swap but the 2jz isnt much harder to swap either. If you get a supra 2jz its basically a direct swap, if you get an aristo 2jz then its more work. If you want to see what you need to do to get an aristo 2jz to work look here:
http://www.supraforums.com/forum/sho...d.php?t=255935
Also you should use search, you'll find more answers then waiting for someone to respond with details.
