UGhhh No power Sputter..SC3
Old 05-19-09, 05:59 PM
Durrr
Durrr's Avatar
Cam position sensor or crank position sensor will do the same thing. Check the connectors for those, and also check the cam position sensor wiring. It has a tendency to rub on the serpentine belt causing a short, and a bog at higher RPMs.
Old 05-19-09, 08:49 PM
SC51
SC51's Avatar
Well drove it all night seems to be quick and way more responsive
Old 02-04-10, 04:43 PM
SC51
SC51's Avatar
Well the sputtering issue is back and its way to cold in Ma to work on . I mean the car feels like my old untuned DSM ill floor the car itll sputter a bit then start to rip?? And idling the rpms will b fine then drop quick then it recovers.. clueless guys.
Old 03-15-10, 10:03 AM
SC51
SC51's Avatar
Guess I shoulda added how I fixed the problem, right before I went NA-T, I noticed small slits in the old spark plug wires and it would spark off the valve cover..very bad. That was the sputtering issue.
LS430inDE.
03-16-18 10:21 PM
rt1970ls6
RX - 1st Gen (1999-2003)
31
02-14-18 10:26 AM
GoCarSc300
03-12-15 09:08 PM
handogg
02-12-13 11:37 AM
skyhawk23
Suspension and Brakes
12-10-09 11:21 AM
Quick Reply: UGhhh No power Sputter..SC3
