Soarer Shifter Extension question
Old 05-26-09, 05:34 AM
tonysc400
tonysc400's Avatar
Default Soarer Shifter Extension question
Hey guys, i currently have a 95 sc400 with a JDM 2jzgte swap done and its auto..i want to convert it to 5 speed using a r154 tranny from a mk3 supra turbo...was wondering i know the shifter will be short and was thinking will a soarer extension do the trick? or do i have to send it to a place like driftmotion to get my shifter extended?
Old 05-26-09, 05:45 AM
RyanV
RyanV's Avatar
For the extension. Send it to BoostLogic, they make these.
You'll need a JZ bellhousing too.
Old 05-26-09, 08:18 AM
2jzlex
2jzlex's Avatar
Yes it will, do the soarer extension if you can find the parts. The R154 shifter is a big ***** and when you get into shortening it and playing with the trajectories it messes with the throw.
Old 05-26-09, 10:05 AM
tonysc400
tonysc400's Avatar
well i see that carslon toyota have them in stock..i see that the extensions are longer then the soarer...is this because the soarer extension is still short for a sc400 with a r154 tranny? and what other stuff other then the soarer housing is needed
Old 05-26-09, 12:45 PM
2jzlex
2jzlex's Avatar
Just search plz.
Old 05-26-09, 01:47 PM
tonysc400
tonysc400's Avatar
here is an update..called boostlogic..they no longer do the extension for the housing...and i will do some more research and keep you guys updated...i saw pics of the soarer extension compared to one from driftmotion...i notice the driftmotion extension they make from your old one is longer then the stock soarer one..is there a reason they make it longer then the soarer stock housing?
BAD954BOI
45
04-15-15 05:41 AM
TRDmike
SC400 / 300 Classifieds
19
01-28-12 08:36 AM
alexna-t
12-02-09 05:39 PM
Tommyd1919
03-21-05 08:22 AM
Quick Reply: Soarer Shifter Extension question
