Compound Turbo 2JZ!!
Old 05-27-09, 11:46 PM
QwkSC
QwkSC's Avatar
Default Compound Turbo 2JZ!!
Who's car is this?
http://www.youtube.com/watch?v=8zM71...e=channel_page
you have too much money, give me some lol
Old 05-28-09, 01:39 AM
Mr.NA_T
Mr.NA_T's Avatar
Sick, Sounds nice...
Old 05-28-09, 01:56 AM
JDMmuscle
JDMmuscle's Avatar
so just so i understand this,
Its pretty much like 2, Single turbo kits put together?
The first turbo, Im guessing here, spools up to create low RPM boost, then when you hit higher RPMS, enough to spool the 2nd larger turbo, the exhaust pressure bypass's the first and Via a waste gate or valve or some type and flows right in to the 2nd larger turbo?
Old 05-28-09, 02:00 AM
JDMmuscle
JDMmuscle's Avatar
yeah im watching this vid and it looks like it spools the first turbo around 2150 RPMS and the 2nd around 4000 rpms?
Old 05-28-09, 06:23 AM
QwkSC
QwkSC's Avatar
That's exactly it, if you've seen the dynosheet it looks like a NA motor but then us realize that it has 750whp and only 3.0l
Old 05-28-09, 06:56 AM
LexusFTW
LexusFTW's Avatar
http://www.supraforums.com/forum/sho...d.php?t=527336
Old 05-28-09, 07:32 AM
2jzlex
2jzlex's Avatar
Yeah if that's the same guy from SF he jsut popped it two days ago.... Sucks to be him right now.
Old 05-28-09, 09:07 AM
Kohinoor
Kohinoor's Avatar
isnt that just a biturbo setup - one small turbo spooling a larger one?
Old 05-28-09, 09:18 AM
Enigma8246
Enigma8246's Avatar
There have been a few threads on this setup already. i'm wanting that kit pretty badly
Old 05-28-09, 09:20 AM
QwkSC
QwkSC's Avatar
It's kinda difficult to explain.
The small turbo's hotside is routed into the big tubo's hotside. So both spool off the same exhaust.
But the small turbo's cool side feeds, through the big turbo's cold side, into the intake.
It really is basically 2 single turbo kits.
Old 05-28-09, 09:56 AM
SC300_704
SC300_704's Avatar
that's Chris car, at least that's what it say in the video...
Old 05-28-09, 11:47 AM
2jzlex
2jzlex's Avatar
I think you know what's happening just explained it wrong, lol. The larger turbo is what's fed by ambient air (atmosphere), or filter if you will. The compressor of the larger feeds the intake of the smaller turbo. So the smaller never sees ambient air, it's only source of airflow is through the outlet of the larger turbo. Then out of the smaller turbo compressor is where the air runs through the I/C.
Old 06-16-09, 11:11 PM
EDTUN3R
EDTUN3R's Avatar
I will be doing this setup this in couple of months! But Im not buying it from Boost Logic I dont have $7k to spend on a turbo kit! lol
sc2.5
Florida Lexus Club
07-14-10 09:34 PM
tuninghaus
10-30-09 08:25 AM
Stage3
01-20-07 08:48 PM
Quick Reply: Compound Turbo 2JZ!!
