1jzgte R154 swap 1997 SC300
#31
Here's a little update with some pics too. My reverse lights work and even the R lights up in my dash, thanks Dr. Tweak. Now I just need to fix the pesky abs light and seems like my power steering isnt working, seems a little tight. Should I have swapped power steering back to the original oem one? I am still waiting on my spacers for my wheels. On to the new pics:
#34
Look's good man, try bleeding the rack. Lift up the front, engine off, turn lock to lock slowly, and repeat that 4 times, start car, turn wheel right all the way to lock, hold for 3 sec, turn wheel left lock same thing. You repeat this entire process several times. It's a pita to do.
Hmm...I spy a Supermoto in the last picture![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
I sold mine to finance the 1jz swap..
http://img.villagephotos.com/p/2003-...2/IMGP1695.JPG
#35
thanks guys, I am trying to make it to you guys levels. I will try to bleed the steering and I hope that works. I am using the power steering set up that came with my 1jz. Also do you guys have this ABS issue that I am having or does yours work fine?
#38
ABS? who cares.. downshift in addition to braking and you are fine.. Or just pump away at the brakes.. VIOLA!... ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
btw to the OP - what part of NY are you in? It is cool if you don't want to answer. I know how us NYC'ers are about details like that. lol
#39
if u send out your harness to Dr. Tweak just remind him to fix your reverse lights and abs which i forgot to do and you should be fine. Also remind him of the tach adaptor.
#40
Cause if its not to bad than i just wont worry about it. but i did want to get the light off my dash board
#43
It's not too bad without ABS except when it's rainy. I've only locked up the brakes twice in the last year. Once while autocrossing in the rain, and once when I hit a patch of gravel on a backroad. I'm not in Colorado in the winter anymore, so I'm not too concerned. Since you're in NY though, I would definitely advise you to look into it...I used my ABS all the time in the snow.
#44
Btw I was in NY this morning forget to get your N#.
Is that a TRD shifter? mine is coming from Toyota tomorrow.
