1jzgte R154 swap 1997 SC300
Old 11-12-09, 05:48 AM
  #106
andrew18
andrew18's Avatar
Hey man good looking project!! Btw if you dont mind me asking what kind of rims are those and where did you get them .. (the rims with the BMW center cap)
Old 11-12-09, 05:57 AM
  #107
BigGreen
BigGreen's Avatar
Good Looking!
I dont remember the make of the rim, but I got them off ebay(they are sold tho)
Old 11-16-09, 06:01 PM
  #108
StiCk3
StiCk3's Avatar
Default Wiring Update
Well after scouring over the diagrams, the ABS ECU connectors, although identical, have pins that are VASTLY different. Also the ABS unit itself is different from the ABS TRAC unit. I'm curious to see if the ABS TRAC unit can be used w/o the TRAC portion functioning. I'll go over it and see which wires need to be rerouted or if it's a completely lost cause. Hopefully it doesn't involve finding another ABS unit that is compatable.
Old 11-17-09, 06:44 AM
  #109
BigGreen
BigGreen's Avatar
I know from before when I connected my abs/trac unit up after the swap if would give me a CEL and abs light. When its disconnected i just het the abs light. I was able to source the abs only unit and have since connected it but i still get the abs light but no CEL.
Old 11-17-09, 04:50 PM
  #110
StiCk3
StiCk3's Avatar
That probably because the original ABS ECU required certain inputs from the engine computer in order to work the TRAC function. When the swap was done the TRAC function was rendered useless, thus throwing the CEL
When the new ABS ECU was installed it didn't require engine computer inputs that the old ECU needed. The ABS light is getting thrown because of the ECU pinouts i mentioned before. The goal is to get these ECU pinouts re-routed so everything will work.
I have a day off tomorrow, so ill spend time trying to sort out the pinouts and see what all else needs to be done.
Old 11-18-09, 04:28 PM
  #111
imarshall
imarshall's Avatar
This is where I was gonna take my car. We deliver parts to redline and everyone kept telling me about the turbo sc over there.
Looks good.
Old 01-14-10, 11:49 PM
  #112
want sc300
want sc300's Avatar
is that one piece CUSTOM drive the only way to do it or would the one from the soarer work?
Old 01-15-10, 06:49 AM
  #113
BigGreen
BigGreen's Avatar
I believe that the one from the soarer should also work just fine. I was in no way able to source something like that out tho so I just lucked out and found someone selling there's.
Old 01-18-10, 07:20 AM
  #114
99SC42
99SC42's Avatar
No you can use the W58 Rear half from an SC with R154 front half from MK3 and bam.
Gary any news on your ABS light?
Old 01-18-10, 03:08 PM
  #115
BigGreen
BigGreen's Avatar
ABS light still on, but havent worked on it for a little while. Kinda took a little hiatus and just been beatin on it to make sure everything else is working and so far so good. Whats the status with both ur projects?
Old 02-28-10, 06:47 PM
  #116
BigGreen
BigGreen's Avatar
Default winter time look
couple of updated pics of how it currently sits for the winter
Attached Thumbnails 1jzgte R154 swap 1997 SC300-imag0161.jpg   1jzgte R154 swap 1997 SC300-imag0162.jpg   1jzgte R154 swap 1997 SC300-imag0165.jpg   1jzgte R154 swap 1997 SC300-imag0166.jpg
Old 03-25-10, 08:12 PM
  #117
Red Bully
Red Bully's Avatar
looks like kings point
Old 11-03-10, 08:49 PM
  #118
mgude
mgude's Avatar
I know this thread has been idle for a while, but... I want to do this exact swap on my 97 sc300 auto. Do you have an estimate of your total costs? What extra parts are needed to get the manual transmission in there?
The car looks great, btw. Still enjoying it?
Old 11-04-10, 06:46 AM
  #119
BigGreen
BigGreen's Avatar
For the manual tranny you will need the actual tranny along with a driveshaft since urs will be too short if i remember correctly. total cost of swap was probably somewhere in the ball park of $6K to get everything done right with a few upgrades.
Thanks, yeah i am def still enjoying the car...thinking of going single sometime next summer if the $$ is right
Old 11-04-10, 02:35 PM
  #120
mgude
mgude's Avatar
Are you including the cost of the engine and tranny in that $6k? How much did you pay for your 1jz and transmission? Any advice of shopping online for an engine?
What do you think of this?:
https://www.clublexus.com/forums/sc4...aser-swap.html
Quick Reply: 1jzgte R154 swap 1997 SC300
