Car Bogs unless MAF is unplugged... Help
I have been recently getting this weird bogging issue. Car feels like its lacking a lot of power... bogs in any gear etc...
While I was at a light, I thought of the idea... unplug the MAF and see what happens. So I did. Then proceeded to drive the car like it was meant to be.
The car ripped... Felt like it had gained a lot of power and there was no bogging anymore. But it is now pig rich. However I do NOT have a CEL with the MAF unplugged... weird.
So what do you concur? Is it the MAF? What else could it be? Why is there no CEL and the car doesnt really have a hard time idling (fluctuations between 600-800rpms).
So now I am forced to drive it without the MAF plugged in because the car bogs with it plugged in.
Take off your driver side wheel and look up into the fender liner, This happened to me as well.... turns out i had stripped a bunch of wires... One of them was my maf wire.
Technically your car shouldnt run with the maf unpluged, so there should be a wire issue some where. Try cleaning your Maf first tho
sounds like it went bad, or needs a really good cleaning.
I've noticed that cars with Karman maf's (92-95) will still run if you disconnect the maf But if you do the same on a 96+ with a hotwire maf, the car won't even start.
like JDMmuscle said, clean it first and see what happens.
Only because of the manual transmission, not MAF. Why?
The wires have not been touched at all (which is good news lol).
Looks like I will try and borrow a friends MAF.
With the maf plugged in, does your car feel like it drives stronger or weaker on very cold start ups? (before reaching normal operating temperature)
This is starting to remind me of the problem Och had with his LS400.
https://www.clublexus.com/forums/ls4...-question.html
Och could never really find a solution, but we narrowed it down to it possibly being a bad ecu. If you can find somebody around, try using their ecu and see if it helps.
If you have an intake system. That would be your culprit instead of the MAF. You would need to get an ECU to accompany your PCM so it can compensate for the Air and Fuel mixture. Many people install the intake and fail to have the ECU programed will cause lost in performance and driveability issue. Hope that helps.
Matt did you ever borrow another ecu from anybody elses car? You could use my brothers if you want since mine is a 95. I think the ECU is bad cause that is weird and it should die once it is unplugged.
