Starting problem
Old 06-08-09 | 11:50 PM
Ryan1989's Avatar
Ryan1989
Default Starting problem
hey names ryan i just bought my lexus about a month ago its a 1992 sc400 black got about 161 k on it it seems to me that everytime i start the car cold it runs fine but then when the engine heats up to normal temperature and then i turn it off it wont start....it wikll just go up to 1000 rpms then putter down and die... also my heat shield is crackling a lot ..butt i got new fuel lines and a fuel filter but the car still will just die randomly?? any ideas at all ?? i was going to get diagnostics ran at this place called rocket motors ?? but i ws hoping to get an opinion on here
Old 06-09-09 | 03:11 PM
eight's Avatar
eight
uh, dunnos, may just need a tune up, plugs wires n caps
Old 06-09-09 | 04:18 PM
topdog849's Avatar
topdog849
check battery voltage with a multimeter while car is running to cancel out the alternator.
Old 06-10-09 | 09:03 PM
Ryan1989's Avatar
Ryan1989
like the car will run fine for days without doing this problem and then all of a sudden it wont want to start so i will have to prime the fuel pump or turn the igniton like three times then turn it over its a weird problem really want to fix so you so check the battery when its running?
Old 06-10-09 | 09:04 PM
Ryan1989's Avatar
Ryan1989
ill post some pics soon i really dont want to take it in for diagnostics ....want to get rims first soo bad
Old 06-10-09 | 09:05 PM
Ryan1989's Avatar
Ryan1989
so you guys dont think it has to do with fuel system..?
Old 06-10-09 | 10:04 PM
sc-driver's Avatar
sc-driver
this guy was having somewhat the same problem as you
https://www.clublexus.com/forums/per...er-signal.html
I think the problem was the Idle Air Control Valve (IACV) was dirty and so was the maf.
Old 06-11-09 | 12:20 AM
Ryan1989's Avatar
Ryan1989
so how much moolah will that run me... i dont know much about the tundra engines yet. whats an maf and where would the idle control valve be at?
Old 06-11-09 | 04:58 PM
StiCk3's Avatar
StiCk3
MAF is the mass airflow sensor. The idle air control is located in the throttle body. Nothing a little CARB cleaner can't fix.
Old 06-11-09 | 05:31 PM
sc-driver's Avatar
sc-driver
Naw man, I heard carb cleaner is NOT good for the maf. They have a special MAF Cleaner at autozone.
The MAF is right behind the airbox. Here is a tutorial on how to clean the iacv:
https://www.clublexus.com/forums/per...rol-valve.html
Old 06-11-09 | 06:11 PM
BigLSC4's Avatar
BigLSC4
I had similar problems and it turned out to be a bad fuel pump relay/main relay.
Does your car also have problems starting when its really hot inside?
My car would start fine in the cold, but after it was driven for a while, it would not warm start. The car starts up then sputters and dies like you said. Then when I try to start it a 2nd time, it keeps cranking but doesn't start.
Old 06-12-09 | 08:48 PM
Ryan1989's Avatar
Ryan1989
ya thats exactly it man i does this randomly at times but then rides smooth i really want to fix it could i fix it like at home ??? or would i need to take it to the shop
Old 06-20-09 | 05:00 PM
miraluna's Avatar
miraluna
mine was fuel pump computer... replacing it fixed the problem...
Old 06-20-09 | 05:04 PM
eight's Avatar
eight
heh, ever replaced a fuel pump before? its kinda nasty. dunno bout the sc's but from what ive learned you have to take the pump out from the gas tank, which means lotta gas comes out lol, not fun to do on any car w a full tank or even a 1/4 tank
Old 06-20-09 | 05:26 PM
miraluna's Avatar
miraluna
I did mine with almost full tank of gas... I had to park on the hill though... but again, my problem was not fuel pump... which I did replace first and had same problem... had to replace fuel pump ECU...
Quick Reply: Starting problem
