soarer cluster in sc300
You wont be able to get the fuel gauge to work unless you get the soarer fuel gauge sender unit. The USDM uses the float-type like most cars. The jdm one uses this 3 long tubes part. I got one for my car but I still need to get it wired. And you will need longer screws for it.
The speedo doesnt read over 180kph. I converted mine to read 180mph and disables speed cut.
Search on ebay "TOYOTA SPEEDO CONVERTER / DELIMTER / KMH TO MPH"
I soldered the tiny chip into the gauge cluster harness and it works perfect. People have been using it in the UK and australia for years and it works fine as long as you properly solder it.
Here's a pic of the soarer fuel sender unit.
![](http://soarer.ace.net.au/F-Guage-07.jpg)
As for the ac compressor not working, I have no clue. Could be unrelated. Maybe forgot to plug something back. Or check for blown fuses such as your cigarette lighter fuse.
I'm so glad the Soarer cluster is working out for you!!! WOO I can't wait for some pics!
Can't say I knew there was a different fuel reader... Hopefully something easy can be worked out. Pics! Vids!
You are breaking new ground so that's pretty damn cool no matter what!
When you look at the cluster from a certain angle I am pretty sure I saw that it is possible to light up Mph instead of Kph, but I might be mistaken there... Nonetheless, glad it's "almost complete." Wonder what is up with the A/C not working?
I'll make a video of it as well. I think ucfa4 has an automatic gauge cluster. I have a 5speed cluster.
