1JZGTE ISSUEs
I love my set up so far,i will use the stock twins till i finish the VVTi GTE swap on my GS.
You got pm
SO i bought a camry accelerator cable for the swap when i installed it was too long and was all over the place ,so i took some measurement and it was 23inches from the TB to the firewall so went to the junkyard and found a 94 corolla and measure the the length of the cable it was about 24inches" et voila tres bien" so it fit perfect just like it was from a TT.
So from this day don't waste your time on the Camry throttle body cable it fits but its too long.
Thats great work. So now we know a better solution to this issue and its probably a lot cheaper than the 50 bucks i shelled out for the tt accelerator cable! So let me know when you get your car up and running for the first time on the streets
Yes The camry cable was way too long and all over the engine lol you dont even see the intake manifold and valve cover all you you see is accelerator cable man lol.
I need a downpipe and wire up my Wideband O2 and ready to go, i cant wait to pull it outside.
The shifter look fine after i put everything back togheter i taught i was kind of tall but it looks perfect .
You cant just use your stock downpipe? the wideband is a pretty simple hook-up just takes a little bit if time figuring out where to mount the gauge.
i thought the shifter was pretty high and it still looks a little high for my liking even though it looks a little shorter than the stock manual. I think that i will get my shifter shortened about an 2 inches or so.
You need to take some pics man. I will take some pics of my inside and how the shifter sits and also get some exterior shots.
I forget, but are u doing this for your sc or your gs?
My 1jz didn't not come with a DP, i wish it did!!!
The shifter looked high before i put the center console back ! but i looks perfect now.
I got so many pics man i will post them tonight
I am doing the swap on the SC but GS is next in a few months.
I would been done long time ago, at first i didn't like the 1JZ spark plug cover that was the reason why i didnt buy the 1JZ i was getting ready to go Na-T and on of the local guys told me to get the 1jz ,which i was leaning more towards the 2jzgte swap .So i drove to NJ to pick a 2jzgte and the by the time i got there it was sold , the only thing let was a few soarer 1j and one 2jzgteVVti the guy wanted me to get the 2jzgteVVTi for 2000$ i was like no it's going in the Sc i am not messing with VVtI in a non VVTI car and didnt wanna come home empty handed so i pick up the 1j now its growing on me so i love it.
here u go, when i first got the car
old engine getting ready to be pulled
the 80k miles GE that i got originally to go Na-T
The gasket kit to lower the compression
The GE block back from the machine shop
The GE head back from the shop
Back from NJ to pick the 2jzgte didnt want to come home empty handed look what is got instead
The W58
Water Pump replaced
The rear main seal replaced
Swapping the front sump with GE rear sump
The Valve cover removed
Front sump removed
Engine installed
Intercooler install for the 1st time
The W58
Water Pump replaced
Front sump removed
Engine installed
Thanks man.
At first i routed it inside the passenger side fender,then i realise i didnt want a lot of bend and a lot of piping so i drilled a hole right at the airbox location right behind the passenger headlight and run the piping thru.
The driver side piping look the same as yours i think.
I measure the shifter last night and it sits about 5 inches of the center console without the shift ****.
I install my stock radiator back in and i love the way my engine back looks( looks like its fill up)
I will be doing the cluster mod tonight so my cluster start working!
The only thing holding me up really is the DP, i wanna get my License Plate on monday.
Let the fun begin.
Let the fun begin.
Thats cool man,
the driver side IC pipping wasnt to bad just modified the lines a little bit and for the passanger side i just cut a little bit from underneath the headlight to give it more room so it is almost a straight line. I had to add the MSD tach adaptor for my rpms to work, but everything else worked fine when i started it up.
I think hopefully I will be driving on monday too! I just want to touch up some things like the reverse lights, and ABS, change cabin filter and it should be a go. I cant wait to let it out the cage.
Where are u located at, I was planning on driving down to the MD/DC area next weekend or the weekend after. We should link up when im out there.
