error code 13?
Old 06-13-09, 05:01 PM
Ryeno
Banned
Ryeno's Avatar
Default error code 13?
My alternator was failing/failed on me. I am like 100 percent sure i had a power surge and after that i get code 13. When i start the car cold, the rpm goes up to the normal warming up rpm range but then instantly drops to 1000 rpm. After that it gives me a cel.
I rebuilt the alt and I thought the ecu might have gone bad so i replaced it. Still have the same problem. Then i checked both cam postion sensors, both good. What should i do/check next?
Old 06-13-09, 05:49 PM
drosan
drosan's Avatar
https://www.clublexus.com/forums/per...ly-solved.html
list of error codes
hope this helps
Old 06-13-09, 06:41 PM
Ryeno
Banned
Ryeno's Avatar
ya i found that post which is why i think its my ecu.
Old 06-13-09, 07:29 PM
GEORGE_JET
GEORGE_JET's Avatar
This is what I found for code 13, they indicate that it is probably a connection problem. I would suggest also checking the harness for signs of damage.
Old 06-22-09, 10:15 AM
Ryeno
Banned
Ryeno's Avatar
bump, need help
Old 06-22-09, 06:56 PM
xxtoobsxx
xxtoobsxx's Avatar
I have this code on now for like a year...maybe a lil longer. I could not find the solution...good luck if u find anything let me know. Mine will turn off on a cold night though...weird!
IS300kidd
IS - 1st Gen (2001-2005)
11-29-12 04:35 AM
chi123
Maintenance
11-04-12 12:13 AM
imDementeD
03-08-11 01:03 PM
rmoriar1
08-11-10 06:33 PM
Quick Reply: error code 13?
